Hi all,
I thought I'd try refitting my bathroom, which I knew was going to be a big challenge as I've never really done any plumbing before but researched and planned for a couple of days then took a trip to the plumbing world shop to pick up all the bits.
So after removing all the old bathroom suite (walk-in shower, basin and loo) I then removed all the unwanted pipe work.
I'd bought pre-soldered copper joints and so carefully put all the new pipe work in place. Before attaching the new bathroom suite I capped off each of the pipe ends and turned on the mains...
Out of 14 joints 2 were leaking.
I was quickly able to remove and replace one of them as it was a corner joint that connected to the end pipe for the cold water bath tap.
However I am left with one joint that I don't think I can remove without having to remove pretty much everything! It's a T joint on the cold water pipe that comes directly from the mains pipe (into the bathroom)
As far as I can tell, it is only leaking from one of the 3 openings. I have tried soldering (flux n all) it but the solder just falls off and it is very difficult to get to.
The leak is quite substantial and I was hoping someone could offer some advice that doesn't require me to remove all the work I've done.
Thanks in advance
Thanks in advance
