- Joined
- 17 Oct 2022
- Messages
- 2
- Reaction score
- 0
- Country
Afternoon all,
I'm planning on installing a solid fuel heating system at home. This will replace an old inefficient wood burner. It will run completely independently from DHW and central heating which is run from a gas boiler to an unvented cylinder.
I think the independent system would be a cheap and simple solution to get heat into selected rooms (bedrooms) when the fire is lit. Also save complications with integrating a solid fuel boiler into an unvented system.
I have a local plummer who will help me install, but I want to do pretty much all the legwork, hence the post.
A couple of questions...
Regulation wise, if it is replacing a less efficient wood burner, and reducing reliance on fossil fuels, can it still be done within regs?
Looking at the diagram below, can anyone see any glaring issues?
Priorities are getting heat into rads as quickly as possible. Most likely not all the rads in the pumped circuit will be in use.
The existing central heating feeds 30 rads and has a large cylinder. Hense why I feel feeding into that system would be ****ing in the wind.
Thanks for your time
Chappers
Chappers
