Solid surface worktop or laminate help
bmx
3 Sep 2005
I have been looking for some solid surface worktop that i can fit using my jig and router and all i can seem to find is earthstone. They only have a few colours. Are there other brands that can be fitted like a laminate with the jig?
That's not how you joint solid surface properly, but if you want to, good luck!
Is earthstone not a chipboard and stone sandwich?
The earth stone i fitted was chipboard and resin type material sandwich, comes up seamless if you fit it properly, but you don't neccasirly need a router, you can joint it with a festool skill saw, initially!
If you want to do stone yourself, I wouldn't bother, get the skilled trades in.
The Germans do a huge range of laminate worktops see if you can find a German kitchen supplier in your area, or you could try Symphony Kitchens
