worktops solid wood
28 Apr 2010
Aberdeenshire
Hi
I am fitting solid wood worktops in my kitchen,
Just need a few pointers
Do i just use a normal worktop jig to do the joints,
And do you lot put oil on the bottom as well as the top to coat both sides
I have only one join to do, and i was just going to buy a cheap jig and a good trend cutter
Thank you for your help
Solid wood worktops usually have a square edge so it's normal to just butt up to each other.
Always oil both sides of the worktop I usually oil both sides before installation. Once installed, a quick sanding on the top then re-oil.
Ok, i thought you used the jig
But i still would have to use the clamp bolts to pull the worktops together and biscuit joint them together and use a good glue
Also use the router to do the square edges
Thank you
Worktop jigs are made for postformed worktops (to create the masons mitre) As solid wood worktops don't have this rounded edge, there's no need to use a worktop jig to create the joint.
As you say, use worktop bolts and biscuits to pull the worktops together and keep them level. You still possibly need to sand the joint lightly after assembly (just to even out any slight differences in height between the two).
If the worktops have a 1/4" roundover front edge, you'll have to trim this back to get a nice straight and square edge for the join.
