solid wood floor-is this right?
25 Jul 2010
Cumbria
Hello all,
First post here and any advice would be really appreciated. We are having 18mm thick 120mm wide solid oak tongue & groove flooring (supplied by a well known reputable company) fitted.
Its being glued down to a new (dry) concrete floor. Went to look at progress yesterday - half of its down. But there are gaps up to 2mm along the length of some of the planks. I assumed that the flooring would be butted up tightly (like the pictures in the catalogue and on the sample in the showroom) with no gaps.
I called the contractor whos fitting it to ask why. He told me the planks are different widths. I went back to check and it looks like he's right. Some are 118mm some 121mm.
This appears to be causing gaps all over the floor.
I have supplied the floor, but not paid for it yet. Going to call the suppliers first thing tomorrow and ask them to come and look at it.
Does it sound like the flooring is a bad batch and needs to go back? Don't know what to do for the best. Any advice appreciated.
Thanks.
That's the main reason there are gaps all over the floor. Does your floor also have random length, with a lot of short lengths?
Has the supplier had a look yet and so what was the answer?
The supplier has been out for a look this morning. They have agreed its a fault with the floor and will send out a new batch. They will also cover the cost of lifting the bit that was put down.
Cant fault them for the way they have dealt with this. Looks like it will all be taken care of.
It does have a mixture of legnths some quite short up to some over a meter.
