Solvent Cement for mix of ABS and PVC pipe
16 Oct 2021
Ireland
I've to fit some runs of PVC and ABS solvent weld waste pipes. Have only used PVC waste pipes before and typically used this solvent cement - however I noticed it specifically states It's for PVC pipe. Will this solvent cement from Screwfix do ABS (and possibly PVC also)?
@denso13 What about converting from PVC to ABS. Was going to use 32mm White PVC internally and convert to 40mm Black ABS where it goes external but now wondering if this reducer is only meant for ABS to ABS? If so, I'll just have to do everything in ABS I guess internally rather than faffing around converting from one to another. If so, any issues when connecting to a basin with ABS?
I should also note I was only moving to ABS externally on the recommendation of someone on the other thread I had that you were involved in also
