- Joined
- 22 Oct 2007
- Messages
- 131
- Reaction score
- 0
- Country
I've decorating/renovating a c.1895 terraced house, solid wall construction.
In the rear upstairs bedroom we have two damp patches which have resulting in the plaster blowing, about 20cm diameter, one under each end of the window sill, above the ends of the radiator. Window is double glazed and does not get condensation on the glass so I'm assuming its penetrative. Outside everything looks fine, (rendered and painted with Sandtex paint I think) no cracks or missing sealer around window, only thing I noticed was under the exterior window sill, some of the paint seems to have lifted, its still secure but I'm I expect a few jabs from a screwdriver would see it flaking off.
Whats the best way to solve this, is there a clear sealer I can use on just the affected area or will I have to remove the flaky paint and repaint (if I can find the same colour).
Also, how long is it likely to take to dry out once the source of the problem is sorted...plaster has been bare for 4 weeks now (before it had thick textured wallpaper hiding all these nasty bits) and still damp.
Thanks for any help
Thanks for any help
