someone please help!!
9 Mar 2009
Northamptonshire
hi all ive got a problem where my central heating comes on when i put my hot water on the only way to turn it of is to switch the boiler of at the mains
i thought it was the motorized head (2 port ) so i replaced that and everything was good for about a week now its happened again my boiler is a potterton suprima 40l sorry if this is abit vague but im no expert at this
could be the programmer.
when it happens have you tried turning the wall stat to 0 ?
the valve may be letting by.
on the end of the heating valve is a lever push it across is it floppy or has resistance on it ?
what make of valve is it ?
if theirs no resistance then the valve is open.
can you use a multi meter to check the electrics ?
find the cable from the heating valve in the main wiring box and check for live on the brown wire to that valve.
you say the lever has no resistance so the valve is open.
i would say its either seized open or its get power to open.
you can also isolate the mains power to the heating system
then see if the lever has resistance.
wont be able to do that untill tomorrow tools at work but
if its live then what?
if its not do i need to replace something in the boiler?
try this take 2 mins.
sounds like the valve is jammed open position the brass part.(useally crud in system )
if you do the same on the hw one that should have resistance.
Pcb fault. Notorious. :wink:
