I'm a novice to testing sockets so what do I need to know and what do I need to buy ? Toolstation has plenty of voltage testers. I want to make sure that the one I buy tells me what I want to know.
RCDs trip when current is leaking to Ground ( the current in the Live wire through the RCD sensor is not the same as the current on the Neutral wire )
You need to find where the current is leaking.
It leaks through defective insulation, water and bodies.
To test the cabling you need a means to test the insulation resistance of that cable and the knowledge of how to use the device.
Tool Station do not appear to stock the insulation resistance measuring devices you will need.
"Megger" is the name of one of the nost popular brands.
Toolstation sell multimeters and voltage testers, but they aren't really the right tools to diagnose a fault like the one you have.
You need an insulation resistance tester - which is a device that tests resistance between two wires that ought not be connected and measures the (hopefully high) resistance between them - but whilst applying a high voltage (usually 500V or 1000V).
They're a specialist bit of kit that any electrician will have, but very few DIYers would get.
If you suspect the kettle, can you just replace it?
