Anyone have any horror stories or success stories with these?
Short story even shorter...upstairs neighbour, apartment converted long before Building regs...impact sound is BAD. I persuaded him to get decent thick underlay (tredaire red, good heavy underlay) and its helped very slightly but as his flat is currently vacant I wanted to get in there and install something more significant.
I have seen a number of different solid panel-based solution, usually variants of 20mm+ chipboard/MDF/cementboard tongue and groove boards with foam or felt layers on the base. These go straight under the existing underlay onto the floor, (separated from the walls by a 5mm foam strip to prevent the impact sound flanking from the floor to the walls)
The only bit I don't get is..how does the carpet fit? The acoustics panels are not intended to be glued or nailed to the floor, the whole point is they are "decoupled", and the suppliers say the carpet grippers can just be glued to the actual sound panels but as they are not "fixed" to the subfloor I'm not sure how this can work without carpet/underlay shifting...?
