Hope Im posting this in correct area of the site.
I live in a victorian conversion flat on ground floor, there is no sound insulation between us, and the flats were badly converted by bodgit and run workmen many years ago . I am looking for a solution which does not involve removing the ceiling which is very decorative around the edge and center. Plasterboard tends to be thicker than the decorative edge, so would stand proud.
The ceiling is just regular joists onto brick walls with ( I suspect) lathe & plaster on top. Upstairs they have tiled floors and all hard surfaces. I can even feel the vibrations from above coming through my own floor as they transfer down the brick walls.
My lounge is directly below the upstairs kitchen, and i can literally hear a spoon being put down on the work surface along with every other kitchen noise ( including machinery-which is horrendous)
Ive looked at using expanding foam to be blown in between the joists, acoustic plasterboard, rubber matting applied to the surface and loads of other solutions but still cannot decide if any will work. I don't want to cover up the ceiling decoration or spend thousands. Is there anything that may work to deaden the sound from above? Im don't want to suspend the ceiling or cover it up.
I also get noise from next door through the wall, but that's another story!
