I am creating a new upstairs bathroom. The bathroom will be towards the rear of the property so as to have easy access to waste water pipes. The bathroom will be between 2 bedrooms so I need to minimize the sound as much as possible. We don't have too much space to work with so cannot have cavity walls.
Which is the better solution, using 15mm sounbloc plasterboards or doubling up standard plasterboards using green glue?
Is it worth adding an extra layer of plasterboard to the ceiling for added sound reduction?
I am also thinking of using earthwool rock mineral insulation between the joists under the bathroom to reduce the sound level further.
The bathroom will be tiled from floor to ceiling and I am hoping to source some acoustic pipe insulation but don't know if they are available from high street retailers.
I am unsure about the type of door I would need for further noise reduction so would welcome your suggestions.
Please let me know your opinions on the above and whether there are alternative affordable solutions that I should be thinking about.
