Spa Bath - Possible airlock?
28 Jul 2012
Surrey
I have a system pool spa bath from around 2000 from what I know, which I have only used once up till now when I first moved in 2012.
Today I filled it up and put some chlorine granules in to disinfect it and it was working fine until I turned it off briefly to fully open all the jets. When I turned it back on, the pump just hummed for a few seconds before cutting out.
I have since tried draining and refilling the bath, loosing's the bottom union on the pump to check for air, and trying to suck water through the jets. Sometimes a few air bubbles may come through, but pump always cuts out after a few seconds.
I am now wondering if it is a simple air lock or something else like a blockage or blow start/run capacitor?
Also in video form:
Regards: Elliott
Update: Found the problem, 12 uF Run capacitor has died and is in a short circuit state.
