Otherwise before this fault it works well
maybe the condensate pipe is blocked, thats what most plumbers say
It is likely that the manual credit switch is wired in parallel with the coin slot switch. If the coin slot switch was electrically stuck on this would render the manual credit switch U/S. Try disconnecting the coin slot micro switch (one of the two connections will suffice) and see if the manual credit button will work........The coin just goes straight through. The little black button that can manually click up credits
... doesn't...
Have you tried turning it off and on again?
Sorry Bod, Notchy made me do it.
Andy
Any use?
Your so silly.
Andy
Very first how handy are you with a multi meter
Rubbish but I've got all the time in the world
Good stuff, anyway lots of info if you google, let me know if you're struggling ill try and help you resolve, lots of versions out there so first thing look up how to identify your model version.
I've always wanted the Asteroid version of your table!
