    Dismiss Notice
Space saver spare wheel
Discussion in 'Car Repairs / Maintenance' started by jjb1333, 12 Aug 2018.
  1. jjb1333
    jjb1333
    24 Apr 2008
    139
    Thanks Received:
    Essex
    Country:
    ADVICE PLEASE.............I have a citroen picasso with 17" wheel
    I have a 17" Ford space saver wheel from a Ford Kuga but the stud holes are different.. Is it possible and could i use it in case of an emergency puncture if i re drilled holes in the wheel to fit my picasso.
  2. rsgaz
    rsgaz
    28 Jul 2014
    1,338
    Thanks Received:
    368
    Country:
    NO!!
    It's not just the stud pattern that is wrong, the centre bore is also wrong, and the offset is wrong.
  3. JohnD
    JohnD
    15 Nov 2005
    55,532
    Thanks Received:
    2,826
    21st Century
    Country:
    Cook Islands
    You can buy an original wheel for your car from a scrapyard for a very modest price and should be a perfect fit.
    Usually I'd say don't use a second-hand tyre, but spare wheels and tyres are very often new and unused. Look at the date code as even an unused tyre will perish with age (surprisingly, more quickly if it isn't used). Ten years is long enough.
    The wheel-nuts fitted with alloy wheels are not the same shape as those fitted with steel wheels, so get one that suits whichever your car has.
    My preference is for a full-sized matching spare, but in some cases, they won't fit in the space provided. This is more likely if you have big alloys.
  4. wgt52
    wgt52
    25 Apr 2016
    443
    Thanks Received:
    86
    Country:
    Don't be a B***** fool... unless you have the tools to do the very accurate drilling and forming of the stud or bolt holes. I would expect your insurance company to disown you if you had an accident with a modified wheel. Having had modified cars in the past I know the difficulties in getting it right and SAFE.
    Changing the drillings on a car wheel is a very specialist job - getting the Pitch Circle Diameter right, the right size holes and the correct shape of the countersink; let alone the size of the hub hole.
    • Like Like x 1
  5. Motman
    Motman
    27 Feb 2017
    2,005
    Thanks Received:
    261
    Essexshire
    Country:
    Many years ago as a teenager, I did banger racing. I had the bright idea of fitting the wheels on the 'other' way round to give me more track. The nuts pulled through and the wheel came off on my second lap!
    • Like Like x 2
    • Thanks Thanks x 1
  6. jjb1333
    jjb1333
    24 Apr 2008
    139
    Thanks Received:
    Essex
    Country:
    Many Thanks everyone for your help and advice..
  7. DaveHerns
    DaveHerns
    11 Nov 2009
    2,584
    Thanks Received:
    207
    Country:
    The tyre you have MAY fit the correct rim, if that's any help.
Loading...
Share This Page
