Spacing of down-lights for even illumination
25 Nov 2004
Is there a magic formula for spacing down-lights to give an even light? I’m supplementing and giving an alternative to existing lighting by putting 4 down-lights into a 15’ X 12’ room. I was just going to space them evenly but thought this may give more light to the centre than the edge of the room.
regards
downlights are tricky - especially with low ceilings. If you want to work out the area covered by each light, i think some simple trigonometry would do the job - based on the stated angle of the bulb's beam and the distance to the floor.
4 downlights will give 4 pools of light in a room that size. However, if you want more even light distribution, use GU10 fluorescent lamps. They are about 2-3 times the price of regular ones (£5.99 at maplin) but they will last longer and give a much cleaner, better light than a halogen, and the beam is wider (I saw some in action, and they dont really have a beam as such). Only drawback is you cant dim them.
Thanks crafty,
not much good at trig! Have drawn it out on graph paper and by having 3 evenly spaced lines going across the room and ignoring the middle one, the remaining 4 intersection would appear to give an even spread. I hadn't heard of 'GU10 fluorescent lamps' but they sound ideal.
available form all good wholesalers / lamp stockists
looking at those, your offering looks like it would be brighter, breezer, but they both claim to be the same wattage.
by the way, Maplin's have gone up to £7.99 now. IIRC, they were in the sale before.
Can't find the site where I saw a review on these or similar ones.
The users comments where that they are too big and stick out rather than being flush with the mounting as a normal GU10 does so take care before ordering :)
