Span table that includes 250 x 47mm?
11 Dec 2018
I'm trying to find a span table that has the above size on it.
Does it exist?
I've got a flat roof that looking at the tables I can find a 220 x 47 isn't quite strong enough but 250 x 47 could work.
To go up to the larger 3'' width stuff could add a fairly significant price to the roof so I'm just considering options currently so see if it would work.
Yeah I'm waiting on a quote back for I beams.
I'm just considering all options at the moment.
The span tables usually give spacings for the joists- typically 400/450/500 mm etc.
If a 220 x 47 isn't 'quite strong enough', have you considered using that section size but at closer spacings, eg 350mm, or even 325mm?
That way, each joist is carrying less load and the bending stress and deflection will be correspondingly less.
And how is the OP meant to prove that this idea is adequate?
That's the whole point of span tables, use the tables and you don't need to prove anything. Don't use the tables and you do
