Speaker output when using 2 remote keypads?
17 Jul 2010
Tyne and Wear
If I have 2 remote key pads and I want to use the speaker output, do I need to output from both panels or is 1 sufficient?
Will audio be directed to the speaker no matter which key pad is being used or only the one with the speaker wire connected
Not a clue without some idea of what system it is you are playing with- audio, video, alarm- who can tell
Texecom Premier Elite
I note the panel has a Spk+ and Spk- also.
Are the connections on the remote keypads the same, and do I just need to connect 1 of them?
Maybe I'm not asking the question correctly.
What I want to know is:
Whether I chose to output the speaker from either of the 2 remote keypads or the panel, do I get the same result?
So therefore I only need one output from any one of them (the most convenient)? I.e. if I output from the panel there is no point in outputting from elsewhere?
