i am renovating an old property, and have come to the point of needing a heating system. i have fixed the roof, insulated it, and replaced 21 draughty windows with new double glazed ones.
currently the house has 2 combi boilers fitted, one serving hot water downstairs and heating upstairs, the other vice-versa. one boiler is a very old ferroli, and the other a new ish vaillant. i am resigned to the fact i will be losing them both.
the house has 4 bedrooms and 3 bathrooms. i am taking one bathroom out, and making another into an en-suite, meaning the property will have 1 bathroom and an en-suite.
the ceilings are quite high - about 10ft, and the rooms are quite big. i filled out a radiator calculation form, and it reckoned that the four largest rooms would need about 11,000 btu each.
so, i have an opportunity to spec pretty much whatever i want, but the question is, what? i know nothing about the subject, and am getting conflicting advice. BG reckon an unvented system is the way to go, as after turning 3 taps on, we measured a flow rate of 21 litres per minute, about 7l/min for each tap. BG think this means we cant have a pressurised system, but are returning with a surveyor to check properly.
another fitting company reckon this is no problem, and a vaillant pressurised system is the way forward.
so, any ideas / suggestions / tips / things to avoid?
