Split Joint on Lead Pipe
17 Jan 2003
Have discovered a split T joint on a ~4" lead waste pipe from bath. The access is extremely tight and awkward. The joint has partially split away from the main run and leaks - can it be repaired using a special tape?
you could try "duck tape" but i thought all lead pie was either banned or scrapped
if its lead why not either solder it up or solder a lead patch over the hole.
just clean the area first and use regular flux and solder.
aleks
