Spotlight bulb- bulb replaceable or whole unit?
5 Jan 2007
London
Hi Everyone
Please see pictures. Can bulb only be replaced or does the whole unit need replacing. By whole unit , I mean all that is hanging from the cable. There doesn’t appear to be any way of getting the bulb out of the housing. I had a look and it doesn’t look like the bulb itself drops from the casing like ones I have in my kitchen.
Also what is the name of the this type down light please?
Many thanks
Thank you. Seems the one I have is not available any more . Can’t seem to find exact match
Is there a direct replacement I can fit myself? Am not an electrician so looking for a straight forward replacement please
that's an integrated led downlight mate, the led chip and driver are built into the fitting so there isn't a separate bulb to drop out. pain in the neck when they go, you just have to replace the whole unit. if you pull the fitting down out of the ceiling spring clips, the wattage and cut-out size are usually printed on the side so you can grab a matching one from screwfix or toolstation.
It's my policy to only buy light fittings that can have a ordinary, off the shelf "lightbulb" fitted into it.
Even if it is occasionally something less common, such as an SES pygmy or candle.
(My fridge and cooker hood, respectively)
Matching as in mechanically compatible and the same power consumption? Indeed.
Matching as in the same lumens output and colour temperature? Ah...
