- Joined
- 26 Jan 2005
- Messages
- 266
- Reaction score
- 0
- Country
The spotlights in my bathroom were 'bodged' slightly by the guy who installed them.
Each spotlight is currently 'daisy chained', but the wiing is messy and the lights were not really designed to have two lots of cable going in/out from them.
I have been advised by my electrician to use junction boxes for each spotlight to run off one single cable into each spotlight.
The trouble is, I want to fix the junction boxes to the beams in the loft. The standard junction boxes will not fit on the beams (75mm diameter) but I have found some 5Amp ones that are only 60mm diameter and will therefore fit.
Is 5A OK on a lighting circuit? I'm assuming that will be fine? Or do I need to lose a higher spec junction box?
