Hello,
My spotlights recently tripped the RCD when I found the offending bulb I noticed the two wires had melted together at the base of the fitting where the bulb pushes in. I pulled the wires apart and cut off the melted wires and the fitting. With the wires cut the RCD wont come back on, I presume this is normal. The forks on the bulb were now black and I presume the fitting is now broken. Any ideas what went wrong and where I can get a replacement fitting.
