Spray paint over old paint
27 Jan 2014
Essex
As in other posts, had a mare with ceiling drying funny with small holes everywhere.
I’m going to buy a sprayer as an investment as I like the idea of a perfect finish.
Question- 1 - will a sprayer fill the existing holes and imperfections or will I need to mass fill smooth
2 - if sprayed over an existing rolled wall, with it leave smooth or still show existing rolled surface through
Spraying full fat emulsion requires a decent airless sprayer. Preferably with a lance for the ceiling. That will set you back hundreds.
A1. I wouldn't expect it to fill the pin holes. If anything it might make it worse.
A2. I can see why you might think that but given how thick the paint is applied, you would need a silly amount of coats.
Properly allied airless on new plaster does give you a flatter finish on new plaster but properly rolled paint should give you a flat finish (not as flat but flat nevertheless).
For years I have toyed with the idea of dropping over a grand on an airless sprayer but I am not sure that it will be any faster than rolling when you factor in the time spent masking and sheeting, and clearing the pipes. I may spend £500+ on a handheld Graco though the next time I have lots of doors to paint in a new build though.
I was only going to get one of the Wagner flexi ones for a couple hundred ? I’m guessing they may be rubbish then?
I don’t want something that was new, left with all these imperfections so I’m facing the fact that I either need to get a power sander on it or skim fill with easifill.
I can only assume that the first ever coats I did dried to quick in the sun or soaked in to the plaster/ board and caused these little holes and all the further coats I was trying to polish a turd. Highly annoying. 36sqm ceiling.
Now to decide what’s quicker, sand or fill
I haven't used the Flexio. It is a HVLP rather than airless.
The reviews on Amazon for the 590 are mostly positive but the ones on the Wagner site are pretty shocking.
https://www.wagnerspraytech.com/products/paint-sprayers/flexio-590-paint-sprayer/
https://www.amazon.co.uk/Wagner-Uni...01BUDJ6TG/ref=cm_cr_arp_d_product_top?ie=UTF8
I have an old Fuji HVLP, it is only a 3 stage turbine, it is definitely no good for emulsion. The cost when new was about £500. The Wagner might be OK but even if it is you will be reloading the cup frequently and you will probably need to strain the paint first. Perhaps I am being unfair but at £100 to £200, I wouldn't expect it to be that good
I agree, but sometimes something are surprisingly handy.
I won’t be fussed if I can get rid of whatever has happened here and get a normal roll on it.
Preparation, preparation, preparation. You can buy the best roller or the best spray system in the world it still won’t look good if your surface area isn’t good. Lipstick on a pig scenario.
I get what you are saying... I am however mindful of those cable TV infomercials for paint pads...
Ok John, so if you can explain what went wrong with the prep and why I have the situation I have on the ceiling and none id the walls, as I don’t recall you commenting on the original posts.
So... the room was boarded and skimmed. 50/50 mist coat on walls and ceiling. Walls dried ok, possibly need another coat. Ceiling has dried with areas of dimples and tiny holes ?
What do you suggest has happened or I did wrong?
It was actually Craig of the original big brother
So it must be good
Yeah, and the Tommy Walsh tools and materials were eventually sold in Poundland (honestly, that is true).
I can believe it, I see his plastic bricklaying mortar bed guide. So many inventions that would be laughed out of trades.
