My house was built mid 1920s and we have been in the house 12 months. I will be starting work skimming/decorating the front room downstairs soon but before I start I want to cure a floor problem. The floor in the room is springy, which is more noticeable towards the centre of the room (about 13ft square). The back room in the house seems fine. When we had the CH system replaced I noticed in the back room that there are brick pillars under the floor about 2ft high, presumably supporting the joists. Some of these had been toppled over to make way when the old CH pipework was installed (bad/lazy workmanship). This does not seem to have affected the floor in the back room but could this be the case in the front room, if so what do I do to sort this out, or could there be another problem with the floor.
