each spur should only supply one single or double socket or one fused connection unit. total spurs should not exceed sockets on the ring (one of the stranger requirements of BS7671). Multiple spurs starting from the same point is an unclear case, its not mentioned in the regs at all (e.g. they don't say you can do it but they don't say you can't either).
