Spurs, how many?
7 Apr 2006
Can someone clarify and advise please? I would like to know if I can run 2 spurs, each supplying 2 SINGLE sockets from a double socket (currently used for kettle and toaster) with no other spurs? The spurs will supply power to 1. Washing machine 2. Extractor hood, therefore not in constant use. Thanks
As I understand the regulations you can only put ONE spur from ONE socket on the mains, but it can be a double outlet. If you need two..then find another socket unless it is a fused spur then it can be run like a radial
If you are doing it in your kitchen you have to get it inspected according to building regs and you need to notify your local authorities building control BEFORE you start the work. If you have an open plan kitchen you can do electrical work if it is more than 3m away from the edge of the sink OR beyond a nearer dividing wall.
