sqm charges oak floor.
13 Nov 2006
Kent
Good evening,
I've been SE for 5 months now and have come to the conclusion that regardless how hard I try I will always struggle with pricing work. Which leads me to this question, i am pricing to lay a 30m2 oak floor, secret nailed onto ply.
I am not supplying floor or trims etc, but will be supplying the ply and laying it prior to laying oak floor, so i am thinking day rate x however long i think it will take plus materials and hire of porta nailer, nails etc, but i know there is also a meterage rate "£20-£30" per sqm, but i don't know if this rate is for laying only or an accumulative rate including the cost of materials fixings adhesives etc?
May I have some direction please.
Good evening,
can only comment from prices "up-north"
........This type of flooring and the installation method is a fitters birthday..
it is one of the most expensive type of floor fitting going
Ply - attracts a cost (labour wise)
Flooring does too!!!!
you should not charge any extra for tools/materials you do not have they are included!
up here we expect to pay around £15 - £20m2 with a minimum charge for this type of flooring and £8-£10m2 for ply (labour only)....
given the size of the job I would try and negotiate a "whole job" rate with a fitter (in other words the job is "this" and I will pay "this" - do you want it?)
....have you considered that you are being offered this work because the client does NOT wish to pay the going rate???
............be careful!!!!!
Thank you for your quick reply lymmranger, I feel there is some confusion, I am the fitter or perspective fitter if you like.
I am not uncomfortable with fitting this type of floor as I have done quite a few previously. The floor they are buying can either be nailed or glued down but not floated. The sub floor is timber suspended with 6" x 3/4" floorboards which are in surprisingly good condition, however still not suitable "I feel for secret nailing" which is why I am intending to use 1/2" hardwood ply as a top up base. Normally I would use 3/4 inch but there is a height issue due to fixed cabinets which form the bases for large expanses of shelving which houses thousands of books "well maybe hundreds" that neither I nor the homeowner wish to remove.
It may be a question of "going rate" I am not so sure, but I have known the customer loosely in business terms for two to three years, maybe it is just a case of whom he can trust. Equally I could price the work at a favourable rate in an attempt to build bridges "his wife is a property developer" this particular work is in their own home.
So if I were to charge a rate from your guide prices top end I would be looking at an estimate of £1425 inc ply, "Cards on the table" I was looking at £850 as an estimate inc ply on day rate x 5 days that's nearly half the going rate, maybe I am to cheap?
There is one thing I find irritating on this site which are those of you who post opinions rather than answering the question asked. I am just looking for clarification on some points, elements I am unsure of and not a character assassination deeming I am incapable.
£850 including supplying the ply is cheap - you estimate 5 days work.....
day rate is at least £200 per day up here!!!!
BUT - you tell us this job is for an influential client............
so...........
If you can live with the "wage" then go for it
You need to be more specific. What type of wood. Solid/engineered. Oil or lacquerd. Dpm?.
Im not calling you out but 6 floors I have went to sand this year all solid oak which have been fitted by chippys and they have been fixed by a paslode gun. One inparticular was 220mm wide pippy oak solid
As long as your making a profit thats the main thing in the early days of being self employed, and pricing work can take years to learn.
Thank you for your informative replies once again, I have been chippying for 8 years now but have only been SE for five months. Up until five months ago I was working for a builder and was earning £60 a day take home, my petrol wasn't paid, neither was any contribution made for the upkeep of any of my tools, I put up with this because I didn't have the self confidence to think I could go out on my own, I didn't think I was good enough, "That's another story".
So with the pricing element, you may think I am to cheap, but that is because I have been earning £300 a week since I can care to remember and survived, so... when I am price jobs I feel quite uncomfortable charging £140 a day let alone £200 a day for my services. I think there is another element to consider here, A floor fitter can charge £200 a day but probably get it down faster and just as accurately then I would charging £140 a day so I think the price from this point of view is relative.
BTW the floor is 20m2 not 30m2 as I was originally informed by the customer having measured it myself. The flooring is solid Oiled Oak 180 x 20mm t&g in random lengths with a minimum of 800mm retailing at £35.99 + vat per m2. It can only be glue down or secret nailed and according to the manufacturer I can use 9mm ply as appose to 12mm ply on top of the existing floorboards as I will be going with the direction of the existing flooring.
So to supply and fit ply and lay new flooring and do a bit of rebating around a fire place hearth I have quoted £1000. To Cheap? To Expansive? About right? Please answer, Thank you once again.
Will2000, I would never put a finished floor down with a paslode nail gun.............I don't own one.
You will need to prime the floor and stick it down with ms polymere adhesive
£400 to put the floor down only would be a good reasonable price
Plus in most circumstances with prefinished oiled floors you
Will need to put a top coat of oil on
The outcome, I gave a quote to said customer at a price I was comfortable giving but higher than my original estimate quoted on here. I was upfront and told customer that the floor could be adhered directly to the floor but this method I am not experienced in and wouldn't take the risk so advised he get someone else, or I can secret nail the floor on a further sub base of 9mm ply a method I am more than comfortable with.
He chose the latter, I am happy and he is happy.
So, I would like to thank those who took their time to guide me once again, I do really appreciate it, Thank you.
