Hi- was wondering if anyone can help.
I live in a new-build flat with a push-button toilet. I know it is a torbeck valve, but am unsure of the pressure.
A short while ago the toilet started constantly filling, rising above the outlet pipe and then leaking through the nuts where it is attached to the wall. I tried adjusting the water level, but nothing worked. I consulted various manuals etc, and realised the best course of action was to replace the valve.
I bought a bottom feed, compact cistern replacement valve from Homebase for 13.49. It looks pretty much the same as the old one, though perhaps slightly smaller. It also has two extra components for a high or low pressure system, which our old valve did not have. It came fitted with the low pressure one.
Installed it, and shortly afterwards we started hearing strange noises. Firstly, when the water has finished filling there is a squealing sound, like there is air and water together trying to get through. More worringly though, minutes after we heard a loud groaning and creaking in the pipes. This would even occur if you just sat on the toilet. As a result we turned our water on and off when ever we needed to flush the toilet.
I thought it might be water hammer, so tried the remedy for that to no avail. Ended up uninstalling it and then reinstalling it. This seems to have done the job with the hammering sound, but not the squeak.
Any advice would be greatly appreciated. Should I completely replace it, and if so with which product?
Thank you in advance!
Karen
Karen
