squirt expanding foam into stud wall for repair, bad idea?
22 Jan 2009
Aberdeenshire
took a radiator cover off and discovered the radiator half hanging off the wall, guess that's why the previous occupants had a radiator cover? :rolleyes:
radiator hung with hollow wall fixings, obviously some noggins would be best but would mean more mess to get them in.
just wondering if i could fill the cavity around where the exisiting fixings were pulled out, then drill and plug into that?
radiator is a double panel approx 70x85 so is fairly heavy.
26 Apr 2005
Expanding foam will do an even less secure of a job holding a radiator up than the plaster board did; you need timber noggins in there.
3 Sep 2006
West Mids
The foam will adhere to the board and solidify the stud and make it stronger
As long as the fixings are suitable high-load plasterboard toggles, then it should be OK
22 Jan 2009
Aberdeenshire
hmm, quick fix would be to chance it and see if it works, if it fails though, i'll have more mess to clear up when I add some noggins. descions.....
it has only damaged the board at the top fixings, so i'm thinking a quick repair there, add some more fixings in the middle and see what happens, really don't have the time to spend on this though, too many other jobs.....
cheers
