    Dismiss Notice
Staining glazed internal doors - how to keep the glass clear?
Discussion in 'Decorating and Painting' started by lizzy, 3 Nov 2016.
  1. lizzy
    lizzy
    21 Aug 2003
    109
    Thanks Received:
    Country:
    I've got 3 engineered oak glazed doors to stain with Johnstones satin wood stain (oil based). a professional decorator friend of mine says he masks the glass prior to ever coat but he says its important to remove after each coat before it dries. But 3 coats on each side of the door means I'd have to mask the doors up 18 times! It will take me longer to mask than to do the staining. I will do it if I have to but has anyone got any other tips? I reckon the stain is too thick to try and cut in against the glass as there is only a small lip on the door. But if I try and do that and maybe scrape off any stain from the glass afterwards would that work?
  2. geraldthehamster
    geraldthehamster
    7 Feb 2010
    2,973
    Thanks Received:
    318
    Country:
    You might find that if you mask for the first coat and get a good edge, you can cut in subsequent coats leaving a mm or two margin for safety. Are you sure you need 3 coats?
    Cheers
    Richard
  3. Sponsored Links
  4. cjard
    cjard
    6 Sep 2008
    2,335
    Thanks Received:
    250
    Country:
    Surely applying a non porous tape as masking (screwfix sell an electrical tape that is 2 inches wide, intended for sticking plastic sheeting together) then it doesn't matter how many times you stain the tape..
  5. Robbie uk
    Robbie uk
    9 Apr 2007
    2,059
    Thanks Received:
    267
    Cheshire
    Country:
    If you mask the doors and you all 3 coats on, then when dry use a very sharp bladed utility knife you can cut around the tape back to the glass and it will come off clean. No point masking 3 times !
  6. Sponsored Links
  7. lizzy
    lizzy
    21 Aug 2003
    109
    Thanks Received:
    Country:
    That sounds like it might be a plan. Thanks.
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
