I'm deliberating over connecting one into the house supply and had a couple of questions.....
1. I was shocked at how much even a manual transfer switch was. The cheapest option I found was a 125A DIN rail mounted c/o switch, in a small DIN enclosure and that was just under £100, but not a make I'm personally familiar with. Lewden? - thoughts on them? If you buy a purpose built rotary c/o switch, they can be well north of £200 which seemed silly for what they are. Because of what I need to power (i.e. bits and pieces throughout the house), it's not feasible to re-arrange the circuits so I have no real choice but to unload and switch the whole incoming supply.
2. What is the recommended/regulation mains inlet method to a house for a generator? I've come across those blue caravan hook up type connectors and I understand they are splash proof so probably not good enough for an exposed outside wall unless they are covered in some way? I've now spotted an IP67 rated version of the same type of connector with like a locking ring/seal around them so I assume something like that would be OK without even a weather cover?
What has prompted me to consider connecting our portable generator in properly was a rather loud bang out in our street the other day, followed by a 6 hour power cut whilst Northern Power Grid dug the road up and fixed it.
The other day......
So we managed to cope fine, and it's just a question of whether it's worth the effort and cost to have heating and the like too. We're not somewhere out in the sticks where you'd expect power cuts to be a regular occurrence - but this was the second such problem in our little cul-de-sac in the last 12 months which doesn't fill me with confidence about the state of the supply cables. I'd appreciate any thoughts on that too from any of you with knowledge of the distribution side.
Thanks!
The other day......
- The gen can power the fridge freezer, and probably some temp lighting too had we needed it (but it could potentially power the c/h boiler and pump too - it's around 1900W cont/2200 peak)
- I have a UPS in my home office that kept the broadband router up for a while
- We're still on a conventional boiler so we had a tank of hot water, and a power shower that allowed us a quick shower each just on gravity
- We have a gas fire we put on to get a bit of heat through the house, with the c/h being knocked out
- We got a gas camping stove going, to sort a hot drink and meal
Thanks!
