Start at the Doorway????
20 Jan 2007
I put some boxes of laminate flooring. In the instructions, it says to lay the first laminate board at the doorway.
Anyone know why?
Well I didnt.
I never had that on my instructions, & if it had I wouldnt have started there.
Reason is to make it easier to install for a diy novice. Depending on what flooring your installing you have to remove the locking system etc to get under door frame if work towards it.
wombats said:
Not so good advice if you have more than one doorway, could confuse people.
Specially with the so-called 'easy' click-systems. Starting at a doorway is a good idea then, but you'll have to same old problem (how to fit in that last board which can't click) when there are opposite doors.
Good old T&G works much easier
