Hi ,
I have a friend that is living in a static caravan for a while with , mains power running from a property about 100 meters away .
The main cable running from the house is the big heavy cable dont know 30mm thick stuff .
The problem is the last 10 meters running into the caravan is standard 13amp cable .
I need to know what the maximum kw you can run off this whithout the cable melting or fuses blowing , she is running fridge , kettle , and just purchased two 500w oil heaters for the winter , also tv and lights are on most of the time .
Thanks , asking as it sounds on the limits to me .
