Sticking LED strips to aluminium channels
23 May 2004
All was going well and then when peeling off the 3M backing one set of strips had no adhesive.
Any suggestions as to what is best to use instead?
Double sided tape- not from a pound shop.
You sure that you didn't peel the whole tape off?
No, it had a tab protruding from one end.
And I had already stuck down two other strips using the same method.
The peel off on this one came off very easily and neither it or the strip was more than very slightly tacky.
Any recommendations as to the type of tape as there's lots out there.
