yes, its probably an entirely different system. Whats the most likely type of central heating for council semi detached housing, if there is one? They mentioned 'brick heating' at first, so I believed it was related to that at first. In the kitchen cupboard, its essentially one very large heating tank, with no room for anything else aside from a timer dial on the right hand wall and its small round button (the one the household always uses to turn off heating when not required-switching off, the heater can cool completely). Below this timer and its button, are two white switches, identical to 2 seperate mains light switches, next door to one another. One is obviously for the timer, as its connected via a short grey cable. The larger switch is probably for the entire heating system, as the heater itself has no controls or buttons at all, aside from a night charge selection of 1 to 6 at the bottom. On top of the tank-very thick large grey tubing from the back leads upstairs/under the flooring, towards each rooms air vents no doubt. The only thermostat in the house is in the livingroom (30 to 80, heating comes on if set above 70, assuming 20 C). Its nowhere near the kitchen and heating tank,practically as far away as you can get in the livingroom, near a window.
I think the heater may only ever charge itself back up during the night, so perhaps it makes no difference what they use to temporarily switch off, whether its via any heater button on its timer, or room thermostat? I suppose it may also depend on how long they leave the system off for at any given time too, as they have said it can lose heat fast, so its probably not cheap to use in the long run. Perhaps switching to gas is the better option where possible if anyone is ever talking about saving, I dont know. Its too bad I dont know the specific type of heating-if I can find images or photos I will post them in future if its not obvious by now, but other than what ive described, theres little else to tell even with pics... aside from the fact that I know very little about heating in general, lol. Thanks for the replies
