Hi.
Just been to a flat that needs a new CU. It's got three storage heaters fed from three 16A MCB's within the main CU. The output of these MCB's are fed into a 3 pole contactor which feeds the heaters. The contactor is operated via a FCU which in turn is fed from a multi-output Meter. So the contactor is only turned on at off-peak hours thus only allowing power to the heaters between these times.
The supply to operate the contactor has no RCD protection. It is simply a 1.5mm cable from the meter to the contactor via a FCU. It's a PME system and all the other flats are wired up this way. The flats are about 10 years old. Is this ok? If not I suppose I could just replace the FCU with a RCD FCU? Any thoughts?
