I want to repair an electric sandwich toaster.....it is a Breville model and I suspect that the cable has been damaged as it has suddenly ceased to work, so I want to check/replace it.
On the bottom of the toaster there is a small 'connection box' in which the cable is secured. The lid of this box is secured by 4 special screws which appear to need a special tool to unscrew. The small screws are partially slotted, i.e., not across the whole width of the screw, just at the edges. Does anyone know if the special screwdriver/tool is available and what it is called? I don't want to throw this toaster out as it isn't that old, but clearly the manufacturer doesn't want to encourage people to dismantle it. Thank you.
