Strange wiring discovered - help
IE works fine out of the box.
FF works almost fine ([SIZE= & [COLOR= need manual tweaking to put the values in, but IMG, QUOTE, U, I & B work with no fiddling) once you've installed the BBcode add-on from codefisher.
I noticed under Options it indicates that HTML is OFF, and there is no way to switch it on:-( I can disable BBCode, whatever that is, and Smilies, but that is unlikely to help... I note the comment about using [quote] and [/quote]Cheers
"BBCode is what you want to be using (as you've discovered, HTML is not available).
It sounds as if, with your browser, you are stuck with typing in BBCcodes manually. You don't have to restrict yourself to just [*quote]...[*/quote] (remove those asterisks when you use them) - you can also use [*u]xxx[*/u] for underline, [*b]xxx[*/b] for bold and [*i]xxx[*/i] for italic etc.(remove the asterisks when you use them) ... even if it is a bit of a pain. Alternatively, use a different browser (not Chrome - that doesn't work, either!)
Cheers, and thanks. Noted for next time...
Kind Regards, John
