Got one that is leaking water (luckily soil stack one only has bath/basin water) not sure why, but as I solvent welded it on what can I so. Is it a case of drying it off and using silicone or is there another way. BTW it's not coming from the rubber insert.
Had the same, turned out to be not enough solvent even though I thought I had used lots. Took it off (broke it off), fitted new one with Loads of solvent, all ok. Assuming it is on a horizontal pipe, the connector is on top ?
I don't think Polypipe ones do. They ought to, you'd think, and most other makes do, but I can't see any angle on Polypipe. Nor is there a locating groove / ridge for boss adaptors, so these don't have an angle either.
1) avoid polypipe drainage. Use a better make like Terrain - use their bits AND their solvent and cleaner.
2) If you've got P then clean everything really well, use cleaner, then their "Our bits don't fit so you can botch it with this " gap filling solvent, and pray.
