Hi everyone,
I hope someone could shed some light on a predicament i'm in with regard to an existing loft conversion. The property i'm in at the moment (end of terrace 1930's) has an existing loft conversion, which is split into 2 rooms, one of which has plumbing for an en-suite bathroom, from lifting up the ply flooring it seems that the original ceiling joists are still in place (4x2). from reading posts these are not really strong enough.
As the extension is already in place i believe i'm limited as to how, or if i can strengthen these joists, coming up from below is definately not an option, and if it can be avoided i would rather not start ripping down walls, although lifting up the flooring isn't a problem.
Is there any techniques i can use to try to strengthen these joists, at present they span from front to back of the property, approx 8m with a loadbearing wall below in the centre, i was planning just to use this space as a bedroom for me & my partner with the ensuite, although not planning to have any heavy wardrobes etc up there.
Any help would be greatly appreciated
