I have a loft which I thought I would like strengthened. The reason for
this is over the main bedroom there are a couple of cracks in the
plaster where the ceiling has been flexed a little. The ceiling is
perfectly flat though (i.e. no sag)
What I want to use the loft for is storage. But I'd just like to have the reassurance that it is sturdy and won't come crashing down.
So I got a (loft specialist) builder round for a quote and another is
coming later in the week. He suggested a method of strengthening which
was good, but I sort of got the impression he wasn't totally convinced
it was necessary. So I'd like some opinions.
I've posted a picture of my loft here:
In total the length is 22 foot, it is 12'6" from the front wall to the
inside load bearing wall and 9'6" from there to the back wall. The
purlins running from the front are 9" x 3" and those at the back are
slightly thinner at 7.5" x 3". the purlins are 10'6" apart.
The beams making the ceiling / floor which run perpendicular to the
purlins are 1.5" x 3" at 16" gaps but for each span there are two
pieces of this each about 15" long which overlap in the middle and are
nailed together. (These bits can't be seen in the photo for the
insulation.) Running across the top of these is three pieces of 2 x 3
which I think simply braces them.
Then coming down are some thin pieces of wood from the roof which
support the ceiling at the apex of the roof and at the purlins.
My question is how suitable is it for boarding out at present and is
there some easy way to make it stronger such as adding some additional
ceiling hangars from the purlins to the beams? I'd appreciate any other
advice or suggested reading.
Thanks.
Thanks.
