Strip foundations on boundary with neighbour
  • Thread starter Thread starter UKG
  • Start date Start date
UKG
14 Aug 2015
Hi all
I wonder if you can help with another problem I have. The building will be next to a fence with the neighbour along the 7m length of the building. I want to get the building as close to this fence as possible. I'm now considering a 600mm x 1000 m strip foundation.
The garden is on a slight incline so I plan to level the area. Creating a circa 2 foot drop (at its highest) along the neighbours fence line. I plan to construct a small retaining wall using blocks laid flat.
Can you offer any advice on how to lay the foundations and build the wall as tight to the fence line as possible, with the consideration for the small retaining wall.
Can both walls be built off a strip foundation sat 800 x 1000mm? Or do the foundations for the single storey building need to be completely separate to the foundations for the small 2 foot wall?
Any advice on this is greatly appreciated.
With thanks
UKG
Is this possible? Will it have implications for damp and the DPC? Or can I build the wall, put the neighbours soil up to it and it will be fine?
It just needs to be designed as a retaining wall with some tanking, there's nothing complicated about it. But making it up like you are is a recipe for disaster.
