Is plywood or normal PSE timber likely to give a stronger fixing than the other? I have heard people say mdf gives a stronger fixing than plywood. Is for adding to a stub wall to create a fixing area. Thanks
Does plywood or normal PSE timber likely to give a stronger fixing than the other? I have heard people say mdf gives a stronger fixing than plywood. Is for adding to a stub wall to create a fixing area. Thanks
Plywood would be stronger screw into wood as it woan't split. But it depends how you fix it to the wall. MDF isn't great, I'd be using chip board or OSB before MDF.
But what are you hanging? Even kitchen cabinets i hung off old floor boards fixed to the block work and it's fine.
