Thanks for reading. I am proposing a rear extension which will be the full width of the rear of the ex council house. The existing structure appears to have a full width (6.6 metres) concrete reinforced lintel which spans the building, with a wall in the middle. Picture attached.
I've done a far bit of work in the house and have always hit concrete when drilling at the this level, although I've not got to the point of hacking plaster off the wall to confirm.
I've googled this and I can't seem to find any information on this type of build and was wondering if anyone could confirm if this is the case?
My main question is, if it is the case, am I right in thinking that it is very unlikely that this would provide the sufficient amount of support with the midway block work removed, I'd be looking at a steel to replace?
Secondly, if that's the case, is removing and replacing this going to be a significantly difficult job (ie expensive)
I am looking to have the blockwork done professionally, but the rest of the work is within my capabilities to complete.
As it falls under permitted development, will it be a case of having LABC carry out regular inspections to confirm it is correct?
Thanks in advance
Sam
Thanks in advance
Sam
