I'm two outdoor lights. The first one is daisy chain wired to the second (or it would be if I could get all the wiring in the available space in the light fitting! I've wrestled with this for some time but can't get all the wiring (which is rather inflexible) to fit. Any suggestions?
Try cutting the connector block up so the connectors can lay sideways and spaced apart, aim to get the connectors either side of the wires going to the lamp. You also need to weatherseal the hole in the box with some silicon or similar.
