Tony
On our first floor bathroom we have two basin mixer taps and a shower mixer. When I have the taps / shower on but all the way over to the cold side the pump does not come on and it is fed by mains. If I mix in some hot obviously the pump kicks in. This must mean that the pumped hot is mixed with mains cold?
Many thanks
Mark
It seems that the mixer is leaking pumped hot back into the mains!
This was suggested towards the beginning.
As I said, mains and pumped should not be feeding the same taps!
BG should have known that and should rectify the problem!
It could be made to work by fitting a double check valve on the feed to each cold tap/shower.
Tony Glazier
