Stud Wall Fixing Into Screed?
14 Nov 2008
Cornwall
Hello all,
I need to build a stud wall in our extension. The floor is 75mm flow screed, polythene barrier and 70mm Celotex on a concrete base. There is no underfloor heating.
Can the timber sill plate be plugged/screwed directly into the screed, or is there another recommended method?
Any advice would be greatly appreciated!
Cheers, Paul.
A 4 inch concrete screw would do the trick. Best not to go near the dpm if avoidable and unless the wall is very long a 2 or 2 1/2inch catch would be fine.
Thanks for your help.
The wall needs to be 3.1m long with a door opening at one end. Aside from the screed floor fixing, the studwork will be fixed to thermalite block walls at either end, and the head plate will be into a steel beam.
Cheers, Paul.
This is not a structural wall and you only need a nominal 25mm (approx) spike to stop any lateral movement - as opposed to some mighty fixings to try and hold the wall down
