stud wall in garage
8 Mar 2009
West Lothian
guys, I'm planning on dry-lining my attached garage by building stud walls and using plasterboard to finish it off.
my question is that one of the walls is a single skin wall built with blocks and rendered on the outside.
I know I need to use some sort of membrane, but I am looking for advice with regards what kind to use and where to put it. and do i only need to use it on the one wall that is single skin, the others are a cavity.
i will be filling in the gaps in the stud wall with kingspan insulation.
here is a drawing of what i was planning
the blockwork wall is dry and sound, there are also 2 high level air bricks and 2 low level ones.[/img]
I drylined our garage when I converted it. used 4" studding and 100mm celotex wedged inside the studding then foil backed plasterboard. No membrane but I did bitumen (or similar) coat the single skin wall. All the work was done under building control - from memory I dont think they specified bitumen coat I just did it as a kind of belt and braces job.
