I was thinking, and it might sound stupid but here I go!
It seems to me that a lot of companies are making an awful lot of £ out of pressurised unvented cylinders!
Why couldn't people just convert a traditional vented cylinder, by connecting the CWS up to where the cold fed in from the cold water tank i.e. the bottom. A double check valve would have to be fitted I guess for water regs. Then an 8 l expansion vessel might be a good Idea as might a PRV, I am not sure how much pressure these old cylinders can take (does anyone know?) but, I should think if the PRV was set to ~2.5 bar it would be ok.
Anyway for the check valve, expansion vessel and PRV its ~ £90. Granted thats only a 117 ltr or a 140 ltr cylinder but one of those pressurised is ~ £500-600. You can easily add on another 117/140 ltr cylinder by linking the two together for £100-120 and another £10 for a larger expansion vessel and so on.
£800 for a 200 litre tank seems like a rip of to me.
So either I should start my own business (make some reasonable money) and convert peoples tanks and safe them a packet or I am talking the a load of S**T. Please tell me if there is a good reason why this would not work, I am no expert.
